| Message |
If so, you will most likely need to replace the coolant lines underneath the manifold, unless you delete them (recommended). You will need the upper/lower plenum gasket and EGR gaskets, balance tube orings, maybe some small vacuum lines depending on the condition of them currently (they may crack). Just pulled my plenum to replace my injectors yesterday, after the first time its like a habit.
